Hello libtetto,
Unfortunately, the theme does not have any such an option that allows you to achieve something like this, sorry! If you want to change the block/module structure, you need to edit the theme’s core files section from the code. Also, if you are not aware of the steps which are needed to take in this case, please consider hiring a freelancer/developer to help you because we cannot provide custom work at the moment, sorry!
Hello libetto,
You should check the modules folder from here -> https://www.screencast.com/t/kAOfdwq4ygV All the CSS of the theme can be found in the style.css file of the theme.
