Changed from NewsMag to NewsPaper: Some problems
Hi! I recently change my site from NewsMag to NewsPaper Theme. I found some problems that I don’t understand how fix:
1: https://imgur.com/jms6JKN
I don’t know if I need delete de Mobile version. I see your tutorial video and see that maybe isn’t compatible have AMP and create an mobile version.
2: https://imgur.com/NJmuj9Z
I see this box and I don’t know what it is and how manage.
3: https://imgur.com/vMIrGQr
In NewsMag I downloaded the Spanish Language Translation and work fine. With NewsPaper don’t work.
4: https://imgur.com/x53MuFz
On mobile version I see in the bottom the same grey box that the point 2
Any help?
1. If you want to use AMP, you can use the Mobile theme plugin with AMP, and set the mobile theme template on AMP version => https://www.screencast.com/t/NcZEyCf9 in this way for the mobile version you’ll use the mobile page created with tagDiv Composer and for AMP it will be using the mobile theme design.
For 2 and 4 seems that the box is not from our theme, but from the GDPR plugin used.
3. Please make sure if these titles are translated in Theme Panel -> Translation -> Translations => https://www.screencast.com/t/dnwyvyIaoJzk
<quote>1. If you want to use AMP, you can use the Mobile theme plugin with AMP, and set the mobile theme template on AMP version</quote>
I activate the option AMP but I still see all this info on my homepage logged as Admin:
https://imgur.com/3gSHC3q
Ok. I change to WP GDPR Compliance plugin. It’s solved
I already made it, but don’t work: https://imgur.com/QTD0BxU
  • This reply was modified 5 years by dcaceres.
I think that maybe I have some old setup from NewsMag on my website. How I can delete all the modifications from NewsMag or NewsPaper and start from zero?
I am not sure I fully understand what you are looking to edit. As an admin that information from the top bar appears to you, it cannot be hidden.
Also, I checked your website, and I saw you have a Pro Prebuilt Website, so the footer template can be edited only from the frontend if it is assigned, edit a page/post-template with tagDiv Composer and go down to the footer => https://www.screencast.com/t/rpfNhfyrF
First, make sure you haven’t made any changes to the files, and please make a full backup to all files and the database, after you can reset theme settings from Theme Panel -> Import/Export => https://www.screencast.com/t/lcGdqHKcY
Hope this helps you!
Thank you anyway, but I wrote April 23 and 24 but since I got no response from you I decided to delete everything on my own and start over
I’m very sorry, but our schedule is Monday – Friday from 08:00 AM to 05:00 PM GMT+2.
