changed my hosting and after using this theme facing issues plese help
hello,
I just changed my hosting. after installing all the files I am getting An error occurred and we could not finish the process.
Please reload the page and try again, or manually update the plugins. this messege.
then i tried from manual setting still Downloading installation package from http://talkwithyouth.com/wp-content/themes/Newsmag/plugins/td-composer.zip…
Download failed. cURL error 6: Could not resolve host: talkwithyouth.com
Please make sure that all the theme requirements are set as in our guide from here -> https://forum.tagdiv.com/newsmag-requirements-for-newsmag/ after that make sure that you follow these steeps to install the theme:
First, you have to download the theme files from your ThemeForest account:
Step 1 – First, navigate to the Downloads tab in your ThemeForest Account and find Newsmag Theme. Click the Download button.
Step 2 – Then, on your local computer extract the ZIP folder called Newsmag -tf. After extracting files, open the folder called Newsmag -tf where you can find more folders (child-theme, documentation, licensing, plugins, psd, and many more).
Step 3 – Now, locate the Newsmag .zip file inside the Newsmag -tf folder.
