changeData Error: Element model id is not in $refEl data!
While reorganizing the NOMAD theme, I’m having this error. It occurs when I try to change the footer side which includes map, contact info, and social media icons and sucbscribe.
Could you please help me overcome it?
Thanks in advance,
Göksel Akkaya
Hello again,
I’ve solved the issue, so there is no need for a help for the above mentioned issue.
But, I am experincing another problem. It is about hiding category on posts. I try to get rid of it and I use hide button on ”Categories” section. But it seems that its not working properly, or there is something else that I could not understand.
I look forward to hearing from you.
Thanks in advance,
Göksel Akkaya
That demo uses a cloud category template, currently the setting that is available in the per category settings of the theme panel to hide categories, does not work for cloud category templates.
Either this will be fixed and made to work, or there will be an option added for the category siblings element, to allow specific categories to be hidden
– http://prntscr.com/nip7vi
Sorry for this inconvenience, please let me know if you have more questions.
