Changes made on Newsmag using visual editor not appearing on the front end
Hi Im using the visual editor to design my website. When i make changes to the template using the backend, the changes are not reflected on the front end once im not logged in as an administrator. However I can view the changes made in the view mode or after I update the changes, only if im logged in.
Please help
Hello mrztaha,
Please notice that you should be logged in as administrator if you want to have some permission to use the Visual Composer editor, otherwise, you will have no permission. Also, please ensure that you are using the latest version theme which comes bundled with the latest version of required plugins. Also, make sure that your system status is properly increased in order to achieve best results, according to our documentation here -> https://forum.tagdiv.com/system-status-parameters-guide/
Hope this helps!
