Changing block settings in footer
Hi – Am just looking for some quick advice as I have stumbled over this for 2 hours now and am sure there is a quick fix.
I am trying to change the block settings in the footer so I can change the text header to be bilingual. Eg change ‘POPULAR POSTS’ and ‘POPULAR CATEGORY’ so that they each have their equivalent in target language.
Does anyone know how this can de done?
Am equally having trouble doing this in the main body section so that the block setting reading ‘LATEST ARTICLES’ would also have an amended header to reflect the translation of ‘latest articles’ into the target language.
Many thanks for your help!
Hi garya,
If you like to change the footer template go in Newspaper > Theme panel > Footer expand Footer setting and choose a style or a footer page ( https://www.screencast.com/t/GNutmYRH8N ), also you can use cloud templates to set footer or to create a footer ( https://www.screencast.com/t/6wdfx3cVU ).
Or if all you wish is to change name you can use translation, in order to acces it go in Newspaper > Theme panel > Translations and expand translation , search the title you want to rename ( https://www.screencast.com/t/6wdfx3cVU )
