changing blog posts related articles order
Hi is it possible to change the ‘related articles’ order and for it to show all of the articles not just related to that particular post?
The related articles section is part of page template and it can be edited from WordPress editor https://i.imgur.com/lpQUD6Z.png
Hope this will help you!
Hi Calin,
Thanks for the quick reply, im referring to a blog post at the bottom near the comment section like here: https://www.dropbox.com/s/rmi6pzihabkdwfv/Screenshot%202021-03-01%20at%2012.39.31.png?dl=0 there it says related articles, this is what i need to change.
Sorry, I was thinking to latest articles.
The related articles can be edited only from theme panel settings https://i.imgur.com/Uic29yI.png and can display only posts related to tag or category, there are no other settings.
Thank you for your understating!
