Changing Comment Section [Colors]
I inserted the following lines of code in, Theme Panel > Custom CSS > YOUR CUSTOM CSS:
.comment-author .vcard .fn a{color:#00FF00;}
.comment-body p a{color:#C0C0C0;}
.comment-author.vcard .fn a{color:#e29700}
.comment-author.vcard .fn a:hover{color:#FF0000;}
.comment-list .comment-meta a{color:#303030 ;}
However, they did not make the changes I had expected. Could you possibly let me know what I am doing wrong here?
(For reference: http://s3.postimg.org/peh0nb9er/Untitled.jpg)
Sometime you have to use the !important parameter to make it work, ex:
.comment-author .vcard .fn a{color:#00FF00 !important;}
Thank you, Emil G.
Hello Emil G,
I changed my code (above) to:
.comment-body p a{color:#C0C0C0 !important;}
.comment-author.vcard .fn a{color:#e29700 !important;}
.comment-author.vcard .fn a:hover{color:#FF0000 !important;}
.comment-list .comment-meta a{color:#303030 !important;}
And it seems no changes were made to the comment section :s
Any suggestions?
Please send a link to your site and point me what do you want to change using this css, I need to inspect this so I can provide an relevant answer.
http://www.Leadnr.com
Basically, I want to change the Content Font from 400 weight to 300 weight for Roboto font.
Use this css: http://screencast.com/t/TGmLb11X
body {
font-family: 'Roboto','PT Sans',sans-serif !important;
font-weight: 400 !important;
Will change the font and font-weight on the whole site.
I will try that code, where should I put it? Btw, I want 300 font weight, not 400. So should I change that “400” value to “300” I’m guessing?
Also, changing the comment section colors using the code you have provided me:
Does not seem to work.
You can see a live preview of my comment section here: http://leadnr.com/featured/heres-to-a-cool-looking-post-page
I can’t see your site so I can’t inspect it to check this. Please provide a link where I can see this issue and also provide more details on what do you want to achieve.
