Changing default background color or posts and pages
Anyone know how to change the background color of all pages and posts from the default white to a different color?
Hello !
Depending on the demo you use you can either do it by going into Theme Panel – Theme colors or by going into your template, and set the background color to your ROW: https://www.screencast.com/t/lP5z6rvRkK
