Changing default post title text hover color
How do I change the default hover colour of my post text titles?
Please provide the link to your website.
Here is the link to my website
https://www.cheadlehulmeweb.co.uk/
I recommend not using standard templates (header, footer, single, category, tag, author, search, 404) and avoiding blocks 1 to 25, or big grid blocks, as these can be replaced. I recommend using cloud templates and flex blocks, which have more options and are more flexible. Using a flex block, you can set the image width and height, ensuring the images will be the same size. Also, after replacing these templates and blocks, make sure to disable the tagDiv Standard pack plugin.
To change the color of the posts title on the standard block that you have now you need to use a custom code CSS
