Changing fonts
How to change weights of articles title on on a page such as the blog page and in within the article? What element is it I need to be changing?
If you want to change the post title font weight, you will have to change it from here: https://www.screencast.com/t/ctReREnb
It depends on the module you use for your blog pages or the module used on the blocks you want changed.
For withing the article itself: https://www.screencast.com/t/Vs5Virke
Thankyou for your response,
How do I find out what module is which?
Example… screenshot attached… I want to change the weight of “This Thailand workshop is making big moves” – How do I find which module this is to change the individual weight?
Lewis
I believe you also asked this on email. Since you are using the default WordPress blog style homepage, the module used to display the posts is shown or can be chosen in the theme panel here
– https://www.screencast.com/t/AjoRzs6f9Fq
Then you can change the font properties for it in the theme panel.
