Changing Links color in footer
I am using default Technology Hub demo theme and I would like to change footer links color (both Links color and Links hover color).
You can see the links I need to change on the printscreen here: https://ctrlv.cz/O8ZL
Please advise how I can change the links color?
Thanks,
Jan
Hello Jan,
Check the theme panel settings from here -> https://www.screencast.com/t/Eprg9ehgIk
Hi Catalin,
Thanks for your reply however I need change links color in FOOTER.
Your advice relates to the links in HEADER.
Please help.
Thanks,
Jan
Hello Jan,
If you want to change the color of them, you need to create your own CSS code using the Inspector Browser and check the results. -> https://forum.tagdiv.com/create-custom-code-using-the-browsers-inspector/
