Chris S
I’ve implemented your speed tips in functions.php – which is great thanks
I’m using EWWWW Image Opt now – should I remove the part of the code that controls this in your php code? Or doesn’t it matter that both are employed? I removed the code and installed plugin but want to put the speed tips code back in too 🙂
This line? add_filter( ‘jpeg_quality’, create_function( ”, ‘return 50;’ ) );
And if yes…is it dangerous or literally a delete the line…
Pat
I guess you could try both methods …
I use that line in there as it changes the default setting from 90 to 50 (although 45 or 55 works better for some folks depending on size of thumbs) as used by WordPress generated thumbs — if using a plugin that calls on GDlibs/ImageMagick on server directly, then the setting wouldn’t impact that.
I’m not sure if EWWW or Smushit call the server libs directly, but one would presume so. I’m using the default WP setup plus mod_pagespeed for optimization (including on the fly conversion/caching to WEBP format), so not using any plugins.
Idea behind that is that thumbs don’t need very high image quality as they are just pointers to the post where the good full size image lives. WordPress presumes every image should be as beautiful as possible at every size, which is kind of dumb in the real world.
