In Google Chrome, Version 97.0.4692.71 (Official Build) (x86_64), in macOS Catalina, the Newsmag layout
can suddenly shift all posts from a center column to the left hand column.
Can anyone remind me what the Settings refresh is in Chrome? Empty Cookies and Cache does not fix?
Is this strictly a Chrome issue or is Newsmag an unwilling participant?
Also make sure you go to ‘settings’ about in Chrome to ensure updated to latest version. I have all sorts of weirdness with Chrome when there is pending update. In chrome you can also do F12 to get to the console view to see if page is generating some error that needs to be addressed in the CSS, or something not loading properly. 🙂
Hi ideabanker, it is looking like this -> https://i.imgur.com/oE6GEZo.png ? If yes, please check to see if you do not have a zoom on the page, this problem can appear if you have a zoom out.
I will also check on iOS, but this will be possible only tomorrow, so if there is a general problem I will see it and try to fix it.
Bravo! Your screenshot is exactly what the home page looks like — or looked like. Upon zooming back in, the problem is solved! I cannot recall issuing the zoom-out command, so should I presume it was accidental? Or is there another function that invokes zoom-out? This latest version of Chrome is the most problematic I have ever seen! Thank you!
