Guys I created new website on clean WordPress and clean Newspaper 10.x,
where I imported DefaultPro demos, without additional data, only layouts.
And now when I looked on default wordpress first post “Hello world” with first comment,
so button Leave comment as answer working,
but under this button is main button “Leave comment” and when I click on this button – so nothink happen !
Please can someone say, is this bug? or not? and if it’s bug how I can fix it?
(I tryed created on localhost same clean website with one change – I imported all DefaultPro layouts with additional data, and here this button works – so must be some bug in layouts because when I imported only layouts without additional data so button not works)
LINK ON SCREENSHOT WITH NOT WORKING BUTTON: https://imgur.com/a/Hxl2Jdm
This topic was modified 7 years by
Josef. Reason: adding screenshot with not working button
Here is second screenshot: https://imgur.com/a/lfcsv1Q
Where is on left side – showed link from website where is imported:
“DefaultPro with additional data”
here button works, and have correct url
And on same screen on right side, is showed website where is imported:
“DefaultPro without additional data”
and here button not works, and have un-correct url
SO NOW I NEED KNOW -> CAN I FIX IT VIA EDITING SOME IMPORTED LAYOUT? FOR EXAMPLE VIA TD EDITOR?
Or I must completly delete ftp+database, and create again new clean wordpress installation?
I need know this information, because we want start our new website with Newspaper with DefaultPro but without bloatware from “additional data”.
I prefer import only layouts without this “additional data”.
I’ve just made some investigations and this problem seems to be related to the cloud header ( this header was made for free users, to can comment without login) , there is no modal set for login/join set, so the popup modal is not load, you’ll need to edit the header template and set the login shortcode on header, after that the modal should work -> http://prntscr.com/pjee71 -> http://prntscr.com/pjeefz -> http://prntscr.com/pjeenj
This should solve the problem!
Hello Calin, I looked on it, but this not help.
Looking on domain: https://test.alfmag.com
Here is clean installation WordPress 5.3 + clean Newspaper 10.1 (without StandartPack) with imported DefaultPro layout without demo data. Only additional we imported all 9 layouts.
And when you look on default wordpress post Hello World: https://test.alfmag.com/2019/11/17/hello-world/
So on bottom are two buttons Leave Reply.
When you click on Leave Reply as answer on one existing comment – so this button works.
But when you click on Leave Reply as new comment – so this button not works.
// when we tested uninstall “defaultpro without data” and imported “defaultpro with data”, so button start works.
And when we again uninstall “defaultpro with data” and import “defaultpro without data” so button again stop works.
Now is on domain “test.alfmag.com installed defaultpro without demo data” and button doing nothink.
We tested it on second domain too, and same bug is still there.
and when we tested it on localhost, with imposting DefaultPro with demo data, so this bug not exist.
Josef.
I can provide for your administration login (nick and password) if you want look why “Newspaper DefaultPro Layout without data” have not working button “Leave reply”.
This website is completly clean (fresh WordPress 5.3 in EN-US language with fresh Newspaper 10.1 without StandartPack).
If you would like to provide this information, just write to me and I can give it to you.
And same problem is with social icons – when we imported DefaultPro Layouts without demo data, so changing social icons style not works – when we click in TDEditor on any other style, so on single layout is still same.
It looks that with Newspaper 10.1 is something bad. Because all works correct if we imported “defaultpro with demo data”, but when we imported “defaultpro without demo data” so exist here these two bugs.
Please send us an email at contact@tagdiv.com and provide admin login, as well as cPanel or FTP if possible. We will take a look. Include a link to this topic in the email.
Hello Calin, we found in newest version Newspaper two new bugs.
On both we created thread. In first thread was answer little faster, and wrote same answer as you.
So, before few minutes we wrote email – with information on both our thread (one of them is this thread), as you can read this: https://forum.tagdiv.com/topic/clean-newspaper-10-1-demo-without-data-shace-icons-not-changing-style/#post-321973
So, now we will be waiting on answer from tagdiv. Thank you and have a nice day.
// Additional information: our wroted email contains information about our two threads, because we found two bugs in newest Newspaper(DefaultPro without demo data) with CloudLayouts:
https://forum.tagdiv.com/topic/clean-newspaper-10-1-demo-without-data-post-not-working-button-leave-comment/#
Josef.
Hello, ok.
And how long you will need have access to our testing website? (what we sended in our email)
We are just feared, that it will take a long time to fix these 2 errors.
Is there any timetable (+ -) when we can expect a new version? it may not be exactly, approximate.
There will be an update to our theme this week.
Also there were been made some tests on Default PRO demo and the “Log in to leave a comment” worked for both options ( with content and without content), is very possible to be an isolate case.
