Click-fraud Monitoring Plugin not working
Hey everyone….
I have already seen a similar post in the forum but for a different theme “newsmag” so to be sure that I brought up the discussion for newspaper theme as well I am writing a new post.
I have click-fraud monitoring plugin that helps against click bombing on adsense ads by hiding them beyond certain number of clicks. It was working with my last theme.
But with newspaper theme as we have to put codes in theme panel somehow the div wrap that is necessary for CFMonitor to work isn’t applied even if the codes are wrapped in <div> tags in theme panel options.
I have already written to plugin developer and awaiting his response. But I would be glad if theme developer also chime in and give the solution as plugin was working before installing the theme.
Regards,
Unfortunately the plugin is not tested to work with our theme and we cannot say for sure if it will. We have no idea of the plugin functionality so we cannot offer a precise answer. The best thing you could try is use another plugin to render the ads such as adrotate and then use your CFmonitor implementation. Unfortunately i have no better solution as this type of plugins is not tested.
