Click-Fraud Monitoring
Hi Everyone,
Just bought a Newsmag theme but my plugin Click-Fraud Monitoring to protected my ad-sens just does not work now with this theme any ideas or is there another plugin that I can get what’s contactable.
Thank’s
Paul.
  • This topic was modified 11 years by ptec1.
We didn’t test the plugin with the theme so I cannot said for sure what the problem could be. Try to contact the plugin’s author and ask him for advice, maybe he will be able to provide a solution. Also we didn’t test any of the plugins with a similar functionality so I cannot make any recommendation in this regard.
@Ptec were you able to find the solution?
I recently bought Newspapertheme and just found that click-fraud plugin is not working. I have written to author as well and waiting for his response but if you can share what you learnt or any workarounds then I will be thankful.
Regards,
@Andrei L.
I read your response which doesn’t really make up as a support 🙂 I can understand the suggestion of writing to plugin author (I have done that part already btw) but to clear out the confusion… the plugin is working fine with other default themes and it was fine with my last theme.
So after newspapertheme installation I request a support or any idea/workaround from you guys as well in addition to plugin author. Lets not racket it to plugin developer… I really hope he is not going to say the same “check with theme developer”
Do the testing… let us know what to do with it and what could be the probable solution.
Waiting for your response
Unfortunately we cannot offer support for plugin implementation. We have not tested that particular plugin and we cannot assure it’s functionality. Basically all plugins were meant to work with WordPress and the default implementation. In order to implement this specific plugin it will require basic php knowledge to edit the theme files and adapt the code to tie it in with our custom one. Unfortunately time does not allow us to provide plugin implementation support. To have the plugin working with a custom premium theme such as Newsmag, where the file structure is different, are required many customizations which takes time and lots of researches.
If you really want to use this plugin we suggest you hire a freelancer to help you with implementation. You can hire one from http://studio.envato.com/
Hassan Fazal, If you find somebody to do the changes in the theme I would like the details.But you never know they may amend the themes so it’s built in that would be a good idea.
Paul…
