Client multi-purpose element does include alt=" (for SEO purposes)
Hi Team,
After analysis by our SEO team, we’ve checked the client element does not have alt element set.
I’ve checked and indeed this is not available.
Is it possible to include in the next build?
  • This topic was modified 7 years by wspeed. Reason: added mail notifc
Same thing with text with image.
Solution is to change line 119 FROM:
$buffy_image .= '';
TO
$buffy_image .= ''.get_post_meta($image, '_wp_attachment_image_alt', TRUE).'';
Hopefully that helps.
I know I should play around with core code, but just in hope that this can be incorporated on the next release for these two elements.
Client and Text with image.
Which multi-purpose element are you referring to exactly? I will make a note of this and pass it along to the developer team. Let me know.
Client
and
test with image
I see it now, those elements don’t load the image alt and title. I will add this on the issue list and it will be fixed in a future update. Sorry for the inconvenience.
