cls problem and how to solve it
Hey team, i have a really bad cls score in core web vitals and cant pas it . o,4 in mobile and 0,13 in pc . I dont have auto ads and all my ads is manually with dimension . Only 1 ads in main page and 3 in articles. I dont know what other do . Can you suggest me how to fix it . I have good speed with wp rocket but my problem is only with cls and cant pass core web vitals. Check my site . https://e-agrotis.gr/
For Wp Rocket if you want please try the settings from our guide https://forum.tagdiv.com/wp-rocket-and-newspaper-theme-optimization-guide/
I also checked the website and the CLS is ok on both mobile and desktop https://i.imgur.com/3GNeaFe.png https://i.imgur.com/wLgo2RS.png what is not quite ok is the LCP on mobile and the FCP that is on limit.
Please check if the tagDiv Standard Pack plugin is enabled and used, normally if the plugin is disable you should get better results also on mobile the lazy loading should be avoided on first images – https://i.imgur.com/U5Z2O90.png
In Wprocket i have the same settings .
lazy loading should be avoided on first images : How can i do this ?
Also i try to disable the tagDiv Standard Pack plugin its enabled.
But why i cant pass core web vitals?
If the Standard Pack plugin is disabled, less CSS will be loaded.
Additionally, the CWV will be updated only after some time, typically taking around 28 days.
I just checked the website pagespeed, and on desktop everything is on green, which is good, but on mobile, one single element is not on green https://i.imgur.com/WN2zvdF.png, and from what I can see, the LCP can be reduced by interfering over the images https://i.imgur.com/6NBenLS.png
– https://docs.wp-rocket.me/article/1387-largest-contentful-paint
– https://www.youtube.com/watch?v=ysV2yO_m4Bk
– https://www.youtube.com/watch?v=teByAZ75R7c
Thanks mate appreciate.
