Coaching pro prebuilt website does not apply perfectly
Hi. I have already tried twice to install the ” Coaching pro ” prebuilt website, but it does not install perfectly. For example: the course page does not open, the video embedded in the title does not appear on the main page, the course catalog does not appear on the main page, etc.
Now I deleted it again and I’m starting to install it for the third time. Please send me the specifics of setting up the ” Coaching pro ” prebuilt website and/or give me the instructions for setting it up.
How do you install the prebuilt website with content or only the design? Also, do you have YouTube API to work the video?
Hello Anamaria,
I tried twice, both times I installed with content, but cours page, or other content doesn’t work 🙁
I have a YouTube channel, but, I don’t khow where is YouTube API, or how to conect with wordpress 🙁 If you can, Please send me a link to the instructions so I can find it.
Paata
P.S. I also corrected the System Status with the requested parameters like this:
PHP Version – 7.4.33
WP Memory Limit – 256 MB
PHP Execution Time – 60
PHP Max Input Vars – 2000
You should create a YouTube API key and add it to the theme panel settings. The guide is here: https://forum.tagdiv.com/youtube-api-key/.
Also, this plugin is installed https://i.imgur.com/Ll5hbIK.png?
hi,
i installed plugin (https://drive.google.com/file/d/1l6xQT02ti7VFy6C6NcHMwNjMKGCb_YO2/view?usp=sharing) and theme content works well beside header video 🙁
I installed youtube api key (), it doesn’t helps, video in header still doesn’t work 🙁 (https://drive.google.com/file/d/1uEjkyaOrG76WUOX2khtAwLquN0863usy/view?usp=sharing)
Please help me, fix header video problem, I really like it as it seems in the demo version.
Paata
I would like to take a look. Can you please contact us via email at contact@tagdiv.com and provide the wp-admin access? Include the link to the topic in the email.
I have sent the requested information to the email.
thank you,
Paata
