Code on top of Post
Hello, i would like to insert a Facebook Like Box on the top of all my posts.
I have a plugin to do that with a code:
<center><p style=”text-align: center;”>[easy-fb-like-box url=”https://www.facebook.com/MagazineFeminina&#8221; width=”350″ height=”300″ faces=”true” hidecover=”false” posts=”false”]</p></center>
But i would like to know how to insert this code on the top of the post automatic. One for all.
I’m using Style 13
For post template 13 you need to edit loop-single-13.php file and paste the code here: http://screencast.com/t/vzn3i0Y3HmCe you can also insert the button inside td-post-content container.
Hope this helps.
Hello Andrei, it works.
I use the easy-fb-like-box plugin and the code:
<center><?php echo do_shortcode(‘[easy-fb-like-box url=”https://www.facebook.com/MagazineFeminina” width=”550″ height=”300″ faces=”true” hidecover=”false” posts=”false”]’); ?></center><BR>
