Where should I paste code social buttons for posts and pages?
I placed in the file before single.php get_footer (); But then the page is not loaded.
<script type=”text/javascript”>(function() {
if (window.pluso)if (typeof window.pluso.start == “function”) return;
if (window.ifpluso==undefined) { window.ifpluso = 1;
var d = document, s = d.createElement(‘script’), g = ‘getElementsByTagName’;
s.type = ‘text/javascript’; s.charset=’UTF-8′; s.async = true;
s.src = (‘https:’ == window.location.protocol ? ‘https’ : ‘http’) + ‘://share.pluso.ru/pluso-like.js’;
var h=d[g](‘body’)[0];
h.appendChild(s);
}})();</script>
<div data-user=”1628830748″ class=”pluso” data-background=”#ebebeb” data-options=”medium,square,line,horizontal,counter,theme=04″ data-services=”vkontakte,odnoklassniki,facebook,twitter,google,moimir,email,print”></div>
get_footer ();
Unfortunately i didn’t do any tests with this one, you could try to add the script in the header – http://screencast.com/t/Wh8grZfkB
And the div in loop-single (if you use the other styles you have to edit all loop-single 1-8 files) – http://screencast.com/t/1NjDdBiLgsf
Also make sure the quotes are not formated, they should look like this:
class="pluso"
Not like this:
class=”pluso”
Thank you, Emil G.
You need to edit the page templates for the pages you want it on and place the div where you want it. For the pages that you build via page builder you need to edit this files: http://screencast.com/t/S6eMK4A2rygi
