Code Syntax Highlighter
I’m looking for your recommendation for a plugin that work with the Newspaper theme, and can highlight the code syntax. I’ve tried Crayon Syntax Highlight but is not working with the theme.
I want to put, mainly, shell, mysql, c, python code on my post.
Could you give me a hand please.
I have tested that plugin and seems to work fine: http://screencast.com/t/fRvnEVRT93mf – http://screencast.com/t/JNeJeyHe1tk
Result: http://screencast.com/t/MwWB5smE
Please try this plugin without any plugins active, leave only Visual Composer and Crayon Syntax Highlight active, maybe is a coflict with another plugin.
Sorry for the delay on the response.
I’ve tried the plugin again, and here is my output:
http://screencast.com/t/ZJyvIka0
It is not working for me :S
Do I need to activate something else?
I don’t know if the problem it is whit W3 Total Cache plugin.
You can try also without any plugins active, leave only Visual Composer and Crayon Syntax Highlight plugins active also empty cache and see if you still have issues with that. Also take a look at plugin settings maybe you disabled something there, I tested with default settings: http://screencast.com/t/hmsXC9T7rWu
Thanks for the help, It seems like the problem was the W3 Total Cache plugin.
More specific, the CDN module, we should to re-upload all to the CDN.
We can close this thread.
