Color of news ticker reset and not responding to settings.
i had the color of my news ticker set to #ffa33a and it still set to that color but it is showing up in white since the update. Any idea why this is going down? http://www.hipegalaxy.com right at the top of the page :/
Hello RezNation,
You should change the color of News Sticker from Theme panel, like this -> https://www.screencast.com/t/lR9LGprhm Clear all your caches, purge CDN files and check the results.
you mean like this? http://s1376.photobucket.com/user/Reznation/media/news%20ticker_zpsinvdtxaa.png.html
yea. where in THEME PANEL do i find settings for the news ticker.
wouldn’t i just be able to change the settings ON THE PAGE the news ticker is on? also, what if I want the news ticker to be different colors on different pages.
It was working fine for weeks and then reverted to white.
If you can tell me where in “theme panel” i can find newsticker settings that would be great. I looked everywhere and couldn’t find it. Your picture didn’t show me where in the theme panel it is and when I change it on page it doesn’t work.
Please advise – Thanks,
Erez
Hello Erez,
Check your system status parameters to be increased according to our documentation here -> Most likely, the PHP memory is exhausted and that’s why the settings will not be applied. Clear all your caches, purge CDN files and check the results.
Thanks fort the message!
memory_limit = 1024M
max_execution_time = 300
max_input_time = 300
post_max_size = 100M
max_input_vars = 10000
file_uploads = 1
max_file_uploads = 35
upload_max_filesize = 200M
these are my parameters are these not good enough? seem to all be above what your documentation says.
this ticker is still coming up as white even tho within the settings it says orange.
http://www.screencast.com/t/PQW5dKLzp70
Is there a master setting within theme panel that I am not aware of? my parameters seem good, so what is the problem here please?
thanks,
ERez
view my homepage at http://www.hipegalaxy.com
Hello RezNation,
Try to use the code below and place it in Theme panel -> Custom CSS area.
.td-black .td-trending-now-title {
background-color: orange!important;
that worked but i’d like it to be #ffa33a do I just replace that with the word orange? sorry not good with CSS. please advise
Ok, I did it. it looks good. resolved. still wondering why we had to revert to CSS to do this though :/
hi, can you please answer my question?
Hello RezNation,
Please keep in mind that if you keep replying you will only delay your answer because we answer from oldest to newest. Posting more and more replies will only move your post to the fresher ones and delay the answer further. For future optimal response time, please only post once and wait for the reply as we answer every message.
You can do this change from TD Composer, like this -> https://www.screencast.com/t/Cn6MBnhKJC8
