Color problem override with multipurpose header 3
Hey i want to locate inside style.css the multipurpose 3 selectors , i have a problem with the initial css that my website is showing , the header is white , the menu is black and the hover is blue , and i want to write the one im using right now so it doesnt override the css . Can you point out to me the css line that i must change the color so i dont get this override every time my webpage is loading?
I will try to help you, please mention which elements you are looking for in the stylesheet or what exactly you are trying to do.
you had helped me before with same issue but with a different header , —>https://forum.tagdiv.com/topic/hello-newspaper-theme-customization/ , now im using multipurpose 3 and i cant find the proper elements to change color so i dont get this css override every time my header is loading. Currently i have picked blue color and green hover , but by default multipurpose 3 header has black color on letters and blue hover and white background color on header background . I wanna avoid this override and do the same as i did in the previous header you had helped me , check previous post and give me the same answer for multipurpose 3 header 🙂 Thank you in advance
All the header styles have a white background by default, set here
– https://www.screencast.com/t/O4vBz904YPl
The top menu black background color is set here (in the plugin not theme)
– https://www.screencast.com/t/QEHlSCbf50
The black color of the menu items is set here
– https://www.screencast.com/t/QyjfkWMXZI
The hover color or line displayed below the menu items when hovered is here
– https://www.screencast.com/t/8NQxEFtsNx
Let me know if you need more help with this.
