Color text on WooCommerce blocks on Edge
Hello
On this page https://www.virtualmagie.com/boutique/livres-de-magie-papier/en-route-john-guastaferro-francais/
at this end Vous aimerez peut-être aussi…
present 3 blocks.
But on Edge, texte are in purple on black so it is not possible to read.
Sometime it appears in white when we move the mouse on the page.
Is it possible to only have for these blocks the title in white WITHOUT color background?
If you have Custom CSS…
Regards
Hello Thomas,
Provide some useful screenshots of the problem so I can identify it closer.
On Edge the title of the block Vous aimerez peut-être aussi… have a grey black background.
It will be logical that they look like the blocks of the Produits apparentés elements.
And on mouse hover, all become dark so it is not readable.
On Chrome
Chrome hover
I have checked your website and I saw that error. It seems to be a strange issue! Ensure that you are using the latest version of the theme, remove all of the untested plugins and check the results.
I installed the lastest version (the 9.01) and deactivate some plugin relate to WOO but didn’t change nothing.
Any idea?
Hello Thomas,
Do you have cleared all of your caches after you have made these changes? Try to create another shop page with those elements and check the results.
Let us know how it goes!
