Column alignment problem after update
Hello, I’ve updated my theme to the latest version (12.3) and also updated its plugins (tagDiv Composer, tagDiv Cloud Library, tagDiv Standard Pack), but now almost every “Flex Block 1” content in my pages which has a number of columns >2 it’s unaligned with gaps in rows, in an unwanted mosaic effect, as you can see here:
https://ilportaledelcavallo.it/category/rubriche/attacchi/
How can I fix it?
Thank you in advance
Please delete the tagdiv Composer plugin, install and activate it from newspaper -> Plugins -> https://i.imgur.com/gHZuNQm.png
Hello Anamaria, I did the following:
– Unactivate the plugin from Newspaper panel
– Delete the plugin from WP Plugins
– Install plugin and activate it from Newspaper
– Empty website cache
But it’s still there
Please let me know what plugin you use for the cache.
I use WP Super Cache, now I’ve unactivated it
We had the same problem.
We deleted and reinstalled tagDiv Composer. We have cleared the cache.
The problem is fixed. We use LiteSpeed Cache.
Best Regards!
Ok, I solved it by deleting all Newspaper plugins and re-installing tagDiv Composer and tagDiv Cloud Library and not the tagDiv Standard pack (which actually I don’t remember why is installed).
Thank you
I’m glad you solve it.
Have a great day!
