I’m also having the same problem and it used to work normally for many years.
What will the tagDiv support area do to solve it? And when? Because right now my site doesn’t deliver to its subscribers a very important item that needs “column text” to work.
Same here, waiting for a quick fix – we can’t downgrade back to WP 6.0 either – since we already performed a lot of updates in this version of WordPress.
Please also, make a general announcement, I am sure more people will experience the same problem after they update to WP 6.0
We are currently working on a solution to this issue and will notify you once it has been resolved.
For the moment, if you can roll back to 5.9.3, you can use a plugin called wp downgrade -> https://forum.tagdiv.com/topic/wp-editor-jquery-is-not-defined/
Currently, version 11.5 is not compatible with the latest version of WordPress.
We will also add fixes for any issues that arise, with the latest version of WordPress in the next theme update.
There was just released a theme update that should fix the reported problems with WordPress 6.0 -> https://i.imgur.com/AXJqh3L.png
