Column wrapping problem
Hi guys,
We are trying to sort a long-standing problem with column wrapping on smaller screens and have not had any luck so far with plugin conflicts or anything else.
We have a single cloud template where the row is split ⅔ + ⅓ for desktop and tablet landscape, but we want it to force full-width columns on tablet portrait as it would do automatically on mobiles.
We may have some errors in the settings because when you scroll down in tablet portrait, the second column is not visible under the first column, but then as you scroll back up it suddenly appears over the top of the first column.
To see what I mean (as I’ve probably explained that terribly), please see here:
https://staging.thecarexpert.co.uk/bmw-5-series-2017/
Any advice would be appreciated.
Many thanks,
stuart
I think that what you can try is to set the percent on each port view per left and right columns -> https://i.imgur.com/p432hcn.png -> https://i.imgur.com/Yv9AS0B.png now it looks that on portrait view both columns are 100%
I hope this helps you!
