Comment and add block bottom Relative articles
Hello! I want the emoticon on the top left which shows the number of comments to change it in script and instead of showing the emoticon to show the word “comment”. Which is the php file that I have to prosecute? Also how can I add a “block” under the relative articles?
prosecute=process
(sorry error)
Hello poporil,
If you want to change the icon for Comments with the word Comments, you have to alter the code where this icon is called, like this -> http://screencast.com/t/WL593sA7lj7 and the result you should see here -> http://screencast.com/t/Rmvt4xr2
For your second request, I suppose that you want to add other block under the related articles. If you want to do that, you have to alter the code from this type of template and use do_shortcode method to add the block. Please follow the next steps in order to achieve as you wish. In continuation, I will give you an example for inserting block_1 in post template style 1. First of all, you have to add the code from Visual Composer like this -> http://screencast.com/t/AxKsYI5m and the code will be this -> and you have to implement it inside this core file, like this -> http://screencast.com/t/KJSfXWdeDpIU and the result you should see here -> http://screencast.com/t/i1x6gGi58bL3
Hope this helps!
Thank you for the message!
The encoding to display the word -Comments- in Blast needs to be done UTF8.
If I do it will be okay? because sometimes the UTF8 and Greek characters destroys the page.
Hello poporil,
The theme has not been designed to use characters in this place but only the image. I showed you the place in the code where this is created. You should try to use this Unicode and see how it works for you.
I did utf 8 and it seems to work correctly
http://www.happytv.gr/choris-esena-episodio-76-77-78-79-80/
when they are 0 comments, reference is not 0 is shown?
To reset Does the photo and to write therein the word in GREEK? and grew up in the width? if so, what is the picture FOLDER with the icon?
Hello poporil,
Please notice that this changes about the characters do not affect the functionality of the comments counting. Here -> http://screencast.com/t/3bqK1243a you can find all the files which contains the fonts of the theme. I have checked your website and I saw that you are using Facebook Comments for each post. The problem with comments counting comes from this reason. Please notice that our theme counts only the comments from the theme and not other comments (Facebook, Twitter, etc) Please try to set the default comments from WordPress and test after and see if your problem is still there. Also, if you want to adjust the facebook comments to shows as expected all the comments from your facebook account in our theme you need more additional customizations and require custom work. If you want to display more levels in our theme and you are not aware the steps in this regard, please consider hiring a freelancer/developer to do this for your because we cannot provide custom services at the moment, sorry! Usually, we recommend the developers from studio.envato.com
