Could you give me some help in how to add post views and comment count to the home page modules? (Not only under large thumbs.)
I would also like to disable the author.
I would like the highlighted meta and not the author name under all titles on the home page: http://screencast.com/t/qcqMuudJrH
For views to appear on module view you have to make some changes to the module file you wan to use and add this line <?php echo $this->get_views();?> to it like this: http://screencast.com/t/mvPFV3j1 then add the get_views function to the td_module file, like this: http://screencast.com/t/0CQ0vPrc
This is an example for the 7 module but you can do it for other module as well.
Result: http://screencast.com/t/nHmm5cLZ1L
Here you have the get_views function: http://pastebin.com/yfvFpeKa
The comments/views icons are added via css using the newsmag font, like this: http://screencast.com/t/HrqO1w3usey
Hope this helps!
Lucian.
There are no image files because the icons are added using the custom newsmag font: http://screencast.com/t/gU7pKrZB
You can use the background-image css property and set an image to be used instead of the font: http://www.w3schools.com/cssref/pr_background-image.asp
