Comment Box is Gone
Hello there,
When I tried to manually add facebook comments to the site by editing the theme, something went wrong in my comments.php.
I then put back the original code but the comment box still doesn’t show back up (see for example http://www.thetika.com/prominence-to-producers-evil-dee-beatminerz/)
What can I do?
And what would be the best way to integrate facebook comments?
I tried some plugins but they all conflicted with the theme or other plugins.
We have tested Facebook Comments plugin and works fine.
Please disable all plugins, enable only the theme required plugins and the Facebook Comments plugin.
Thank you
Okay I should’ve known not to include 2 questions.
My question is; why won’t my comment box show back up?
This is my comments.php
<?php
//removing the comments sidewide
if(td_util::get_option(‘tds_disable_comments_sidewide’) == ”) {?>
<div class=”comments” id=”comments”>
<?php if (post_password_required()) { ?>
<?php } else { ?>
<?php if (comments_open() ) { ?>
<div class=”comments-title-wrap”>
<?php
$num_comments = get_comments_number(); // get_comments_number returns only a numeric value
if ( $num_comments == 0 ) {
$td_comments_no_text = __td(‘NO COMMENTS’);
} elseif ( $num_comments > 1 ) {
$td_comments_no_text = $num_comments . ‘ ‘ . __td(‘COMMENTS’);
} else {
$td_comments_no_text = __td(‘1 COMMENT’);
<h4 class=”block-title”><span><?php echo $td_comments_no_text?></span></h4>
</div>
<?php if (have_comments()) { ?>
    <?php wp_list_comments( array( ‘callback’ => ‘td_comment’ ) ); ?>
<div class=”comment-pagination”>
<?php paginate_comments_links(); ?>
</div>
<?php } ?>
<?php } ?>
<?php
$commenter = wp_get_current_commenter();
if (empty($aria_req)) {
$aria_req = ”;
$fields = array(
‘author’ =>
‘<p class=”comment-form-input-wrap”>
<span class=”comment-req-wrap needsclick”><input class=”” id=”author” name=”author” placeholder=”‘ . __td(‘Name:’, TD_THEME_NAME) . ‘” type=”text” value=”‘ . esc_attr( $commenter[‘comment_author’] ) . ‘” size=”30″‘ . $aria_req . ‘ />’ . ( $req ? ‘</span>’ : ” ) .
‘</p>’,
’email’ =>
<span class=”comment-req-wrap needsclick”><input class=”” id=”email” name=”email” placeholder=”‘ . __td(‘Email:’, TD_THEME_NAME) . ‘” type=”text” value=”‘ . esc_attr( $commenter[‘comment_author_email’] ) . ‘” size=”30″‘ . $aria_req . ‘ />’ . ( $req ? ‘</span>’ : ” ) .
‘</p>’,
‘url’ =>
‘<p class=”comment-form-input-wrap needsclick”>
<input class=”” id=”url” name=”url” placeholder=”‘ . __td(‘Website:’, TD_THEME_NAME) . ‘” type=”text” value=”‘ . esc_attr( $commenter[‘comment_author_url’] ) . ‘” size=”30″ />’ .
‘</p>’,
$defaults = array(
‘fields’ => apply_filters(‘comment_form_default_fields’, $fields ),
$defaults[‘comment_field’] = ‘<div class=”clearfix”></div><p class=”comment-form-input-wrap”><textarea class=”needsclick” placeholder=”‘ . __td(‘Comment:’, TD_THEME_NAME) . ‘” id=”comment” name=”comment” cols=”45″ rows=”8″ aria-required=”true”></textarea></p>’;
$defaults[‘comment_notes_before’] = ”;
$defaults[‘comment_notes_after’] = ”;
$defaults[‘title_reply’] = __td(‘Leave a Reply’);
$defaults[‘label_submit’] = __td(‘Post Comment’);
$defaults[‘cancel_reply_link’] = __td(‘Cancel reply’);
comment_form($defaults);
//comment_form();
<?php } ?>
</div> <!– /.content –>
<?php
}//end removing the comments sidewide
* Custom callback for outputting comments
* @return void
* @author tagdiv
function td_comment( $comment, $args, $depth ) {
$GLOBALS[‘comment’] = $comment;
$td_isPingTrackbackClass = ”;
if($comment->comment_type == ‘pingback’) {
$td_isPingTrackbackClass = ‘pingback’;
if($comment->comment_type == ‘trackback’) {
$td_isPingTrackbackClass = ‘trackback’;
if (!empty($comment->comment_author_email)) {
$td_comment_auth_email = $comment->comment_author_email;
} else {
$td_comment_auth_email = ”;
$td_article_date_unix = @strtotime(“{$comment->comment_date_gmt} GMT”);
//print_r($td_article_date_unix);
<?php if ( $comment->comment_approved == ‘1’ ) { ?>
<li class=”comment <?php echo $td_isPingTrackbackClass ?>” id=”li-comment-<?php comment_ID() ?>”>
<article>
<footer>
<?php
//echo get_template_directory_uri() . “/images/avatar.jpg”;
//echo get_avatar($td_comment_auth_email, 50, get_template_directory_uri() . “/images/avatar.jpg”);
echo get_avatar($td_comment_auth_email, 50); ?>
<cite><?php comment_author_link() ?></cite>
<time pubdate=”<?php echo $td_article_date_unix ?>”><?php comment_date() ?> at <?php comment_time() ?></time>
</footer>
<div class=”comment-content”>
<?php comment_text() ?>
</div>
<div class=”comment-meta” id=”comment-<?php comment_ID() ?>”>
<?php comment_reply_link(array_merge( $args, array(
‘depth’ => $depth,
‘max_depth’ => $args[‘max_depth’],
‘reply_text’ => __td(‘Reply’, TD_THEME_NAME),
‘login_text’ => __td(‘Log in to leave a comment’, TD_THEME_NAME)
</div>
</article>
<?php
I have checked the code you sent and did find some missing lines, you can solve this by updating the theme and try again.
Also check this option: http://screencast.com/t/1Yrhrtw0
Thank you
I restored it.
What facebook comment plugin or approach would you recommend ?
You can use Facebook Comments plugin: https://wordpress.org/plugins/facebook-comments-plugin/
We have tested it and works fine.
Thank you
