Comment box is not coming on posts
The user is not able to comment on the post. The comment box is not coming on posts
First, make sure that you have the comment set to be open; sometimes users set it to close after a few days – https://i.imgur.com/QuEy1iU.png
Also, you can check the single post template if it has the comment element added – https://i.imgur.com/VHNdS29.png – https://i.imgur.com/hEPu2qO.png
