Hi! I am facing comment box issue on my site, I have already set “DISABLE COMMENTS ON POSTS” off but still comment box is not show on my website’s posts. Please help to fix this issue as soon as possible.
Website URL: http://www.pkviral.com/
Works for me.
You need to
a) set the disable comments on posts to OFF (default); make sure you didn’t make that “on”
b) normal WordPress function (see WP codex) – under WP settings > discussion > allow comments
c) if you don’t have that set properly, you can also check the box for discussion, per post from built-in wordpress option
wordpress docs
https://codex.wordpress.org/Settings_Discussion_Screen
