comment box not showing in new posts.
I just bought newspaper, and added a few posts. Theres no commment box in the new posts. But its working fine in the old sample posts.
You might have disabled comments sitewide or on those posts only..
Please make sure you enable this from theme panel: http://screencast.com/t/a2wPcqd4ndo and then check to see if the comment box it’s showing.
Yeah thank you. its done
