Comment Box Not Showing Under Posts
I had enabled comments and all options are enabled but still no comment box shows Under Any Post
The default comments should appear if enabled in all the necessary locations. Check if the comments are enabled in the WordPress settings first (disable auto close)
– https://www.screencast.com/t/cL1kpqQzLgd
Check in the theme panel – https://www.screencast.com/t/uoGi4jK8l
Check in individual posts – https://www.screencast.com/t/FNardINAouU
The comments should appear if enabled in all these places.
