Comment box right below social sharing
PLease how do add this code
<?php echo do_shortcode(‘[fbcomments url=”http://peadig.com/wordpress-plugins/facebook-comments/&#8221; width=”375″ count=”off” num=”3″ countmsg=”wonderful comments!”]’); ?>
SO the comment box appears right below the social sharing in post content
Hello willysawa,
Unfortunately, this type of code does not come from our theme but also, come from FB Comments plugin. Unfortunately, this type of plugin is not tested with our theme and we have no idea about the theme’s behaviour with this kind of plugin and we cannot say for sure that will work 100% in our theme, sorry! Please notice that you have to do some additional customizations through code in order to implement the functionality of this plugin. As a hint, you should add this code for each loop single file according to post template used by you. (for example, for post template 1 you have to add into loop-single-1.php) As you can see, our theme uses the comments from WordPress and we do not provide support for another type of comments, sorry!
If you want to display more levels in our theme and you are not aware of the steps which you need to take in this regard, please consider hiring a freelancer/developer to help you because we cannot provide customization services at the moment, sorry!
Okay, asumming i want to try it out.
plz can you give me the line to put it on the single loop file.
Hello willysawa,
Please check this topic here -> https://forum.tagdiv.com/topic/facebook-comments-2/ because there you can see where you have to add the shortcode from your FB Comments plugin. Also, please read all the plugin’s documentation because there you should find the way of implementation.
