My comment count remains zero and there is no header in the comment section, probably due to 0 comment issue. I have enabled comments and comment counts in “Block Settings”, “Post Settings” and also I have proper configuration in the “Discussion Settings”
I have attached screenshots for reference.
Kindly help me fix this.
Here’s a link to one of my articles which has comments, in this case it case 2 comments.
https://thetechgears.com/4-best-apps-for-music-identification-or-reverse-song-search/
Thanks,
Abilash A
https://thetechgears.com/wp-content/uploads/2021/06/KTXtKatdgK.png
https://thetechgears.com/wp-content/uploads/2021/06/AQEM94O54E.png
https://thetechgears.com/wp-content/uploads/2021/06/TvcYyuGOod.png
https://thetechgears.com/wp-content/uploads/2021/06/Pjh7pvoItV.png
https://thetechgears.com/wp-content/uploads/2021/06/PzeON9yqi3.png
https://thetechgears.com/wp-content/uploads/2021/06/2DcCpYGF7k.png
The issue can be from a plugin conflict, that’s why, please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache(also from your browser) and try again.
If this problem is not solved after that, then we need to take a look and see what happened there.
– admin url and credentials
Our team will take a look!
