comment entry
hello,
i do not want my user to fill mail-id and website in comment section how can i hide these fields and i also want this section sign-up independent. i am not using any sign-up form.
Hello manoj.yadav,
Our theme uses the default WordPress comment system just styled different.
Email is required for posts to operate. You can hide the fields you mentioned using CSS but email will still be required to post.
If you want these modifications you have to alter them either in the code or use a plugin.
