Comment Issue
I discovered that comments are appearing in posts where they where not originally posted.
So I decided to dig deep. I commented on several posts, after clicking submit, it redirects to another article.
I equally deactivated all plugins to see if it was a plugin issue, it wasn’t. So I finally tried to use the default WordPress theme. I activated it, and commented. The issue didn’t pop-up, it redirected to the original post where the comment were posted.
What can I do?
I’ve tested the comment system on my side and works fine: http://screencast.com/t/u4D2iKFW6 I am not sure why this happens on your side but you can try to deactivate all plugins, leave just Visual Composer active, clear all caches and test again. You also can try to make a new local install on your computer, with the latest version of WordPress, the current version of the theme available on themeforest, V 2.3.4, and Visual Composer plugin, then check how it goes.
If you still can’t manage to solve this issue please send us an email at contact@tagdiv.com with your login credentials and we will inspect this issue as soon as possible, also include a link to this topic.
Thanks, issue resolved.
