Comments Problem
Hi team,
I have enabled comments in post settings. thereafter, I do not want user’s name and e-mail id to be filled for comment. To do so, I went to settings –> discussion, there I disabled “comment author must fill out name and e-mail “…even after doing so, it’s still asking for user’s name and email id..How to remove???
You can check my website http://www.careongo.com/riseup
I also want comments to appear before related article section in post’s page. how to do that?
Thanks,
CareOnGo
it’s working, I just posted filling in just the comment text area. Pls delete comment 🙂
Maybe it was “Users must be registered and logged in to comment” option.
Cheers!
  • This reply was modified 11 years by nf_prt.
Hi team,
Thanks for your reply. Ya it is working. But I had some other query. 1) I want to hide the field of Name, Email and Webiste. I just want the comment field to appear. Please help me with that.
2) Also, I want to keep the comments section just at the bottom of the article i.e. before related articles..post which I want to place the block of related articles. Please help.
3) I am facing problems with the tweet button also. When somebody tweets, the no. of tweets do not increase. I tried many times but the tweets just do not increase. Even refreshing the page do not help.
Your help will be greatly appreciated.
Thanks,
RiseUp
1. Please try this custom css – http://screencast.com/t/efIGxQIqT
.comments #author, .comments #email, .comments #url {
display: none;
2. You need to make this change in the code as the related articles code you can find it in the loop single file – http://screencast.com/t/UONppi1E and the loop file is called in the single template above the comments(3 cases – sidebar default, left and without sidebar) – http://screencast.com/t/LcFGBTCrf So you need to find a solution for this
* move related articles from loop file bellow the comments for each case – http://screencast.com/t/Iwt27i8O
* move comments to the loop single file – http://screencast.com/t/VQoOAcgi71es – http://screencast.com/t/rwmluRVk
You have to do this for each post template/style that you use.
3. Please check this without any plugins active except of Visual Composer, clear cache and see if twitter count works.
