Hello – several of my posts are showing up without the ability to make comments. I’ve gone to the theme panel – template settings – page template and ensured that disable comments on pages was not checked. I’ve also gone to the settings of the individual posts and ensured discussion – allow comments is checked. Here’s an example of a post where comments are not showing up https://www.pinkluggageabroad.com/maldives-luxury/ and here is one where they are showing up https://www.pinkluggageabroad.com/fez-to-chefchaouen/. Could you let me know what you think?
Also follow up question on the post where comments are showing up (https://www.pinkluggageabroad.com/fez-to-chefchaouen/), I’d like to customize the Leave a Reply section, where the visitor just needs to leave their name and email, not website and also remove the checked boxes to Save name / notify of follow up comments. Where do I do that?
Thank you
Hello !
That issue comes from the settings found here: https://www.screencast.com/t/SGxOW4EmE You will have to uncheck that.
You can customize it as you can see it here: https://www.screencast.com/t/QXeKLqs8n
