I just installed woocommerce and woo addons from tagDiv. Then mobile version of my webpage on newspaper show only this message:
wp booster error:
td_api_base::mark_used_on_page : a component with the ID: tdx_options is not set.
/var/www/clients/client2/web3/web/wp-content/themes/Newspaper/includes/wp_booster/td_api.php
wp booster error:
Missing parameter: 'file'
/var/www/clients/client2/web3/web/wp-content/themes/Newspaper/includes/wp_booster/td_autoload_classes.php
Desktop version works fine.
Observations:
* started to work once I deactivated tagDiv Mobile Theme
* also started to work once I deactivated tagDiv Woo Label and tagDiv Woo Invoice together
Unfortunately the 2 plugins for woocommerce were discontinued and we have not tested them with the mobile theme. As you probably seen the 2 plugins are no longer available in the theme package. There seemed to be no general interest in these 2 plugins so the dev. team decided to discontinue their development.
Sorry for the inconvenience.
I want to set up a shop but I don’t have a woocommerce plugin. How cand I do that?
Our theme is compatible with woocommerce. It is a free plugin you can install from the wp dashboard: http://screencast.com/t/aRVhzxsb
