compatibility problems with Contextual Related Posts plugin
Hey guys,
I’m trying to add related links into article text in posts with this plugin. Many other people seems to have experience same problem. The list with links shows up twice, doubling with title and everything, one after another.
On that developer support forum author says: “Can you check with the theme author around what goes into the single.php to confirm why the_content is called more than once.”
Here is the discussion, not mine but same problems – https://wordpress.org/support/topic/showing-double/
Is there any way to fix this?
Hello !
If you are using a Cloud library template unfortunately this will not work. We might be helpful with some information if you are using a standard template please let us know which one and we will take a look to see what can be done.
A link to one of your pages that have this issue would also be helpful !
