The 9.6.1 version of the theme coincides with this AMP plugin.
I don’t use the AMP feature of the theme.
I request the download link in the 9.6.0 version of the theme.
Please do not give advice in the form of use our AMP feature for your solution! Resolve the conflict.
Sorry but we cannot resolve any conflict with untested plugins. We have not tested that plugin and cannot provide any solution for untested ones as the support policy specifies here: https://forum.tagdiv.com/support-policy-2/
The official tested and recommended AMP plugin can be found in the main plugins section of the theme panel.
You can download Newspaper 9.6.0 from here:
http://www.filedropper.com/newspaper
The AMP feature of your theme is inactive.
In this case, your theme may not conflict with any AMP plug-in!
Is it correct?
Please update the AMP compatibility of your theme so that it does not conflict with other plug-ins as in 9.6.0!
Hi pesimist57,
Please notice that kind of plugin has not been tested with our theme and therefore we cannot say for sure if this will work as expected with our items, sorry! Both of them are created on WordPress platform but this but that does not mean it works well together. You can try and check how it works if you like that plugin but please notice that if it does not work as properly, we cannot provide support for untested plugins, in this case, sorry!
I’m using your AMP plugin.
Pages open as AMP, but Google doesn’t see pages as AMP. No index.
Sample Page: https://engelli.blog/2019/01/2019-engelli-vergi-indirim-oran-ve-tutarlari/?amp
Google Test Result : https://search.google.com/test/amp?id=rJxHOA78LoBe3GFBKU_xjg
Notice from Google Management Tools.
To the owner of the website: https://engelli.blog/
Search Console has detected that your site has been affected by 2 new issues of AMP type.
Most Important Errors (maximum 5)
Errors can prevent your page or feature from appearing in Search results. I found the following errors on your site:
The URL for the “href” property in the “link rel = manifest” tag is missing.
Top Important Warnings (maximum 5)
Warnings are suggestions for improvement. Some alerts may improve your appearance in Search, and some may turn into errors in the future. I found the following warnings on your site:
The size of the image is smaller than the recommended size
Another one who has the same problem: https://themeforest.net/ratings/2975274
https://themeforest.net/item/newspaper/5489609/comments?page=841&filter=all#comment_21744937
pesimist57.
I am currently having trouble with Web site traffic!
Please resolve the issue.
Deactivate all plugin and activate again. It will resolve your issue…
First Activate Mobile Theme then Activate AMP Plugin.
I use the plugin for the theme. But the page does not appear as AMP.
“<link rel=”manifest” href=””><link rel=”apple-touch-icon-precomposed” href=”https://engelli.blog/wp-content/uploads/2018/04/16×16.png”><style amp-boilerplate>body{-webkit-animation:-amp-start 8s steps(1,end) 0s 1 normal both;-moz-animation:-amp-start 8s steps(1,end) 0s 1 normal both;-ms-animation:-amp-start 8s steps(1,end) 0s 1 normal both;animation:-amp-start 8s steps(1,end) 0s 1 normal both}@-webkit-keyframes -amp-start{from{visibility:hidden}to{visibility:visible}}@-moz-keyframes -amp-start{from{visibility:hidden}to{visibility:visible}}@-ms-keyframes -amp-start{from{visibility:hidden}to{visibility:visible}}@-o-keyframes -amp-start{from{visibility:hidden}to{visibility:visible}}@keyframes -amp-start{from{visibility:hidden}to{visibility:visible}}</style><noscript><style amp-boilerplate>body{-webkit-animation:none;-moz-animation:none;-ms-animation:none;animation:none}</style></noscript></head><body class=”post-template-default single single-post postid-9223 single-format-standard” itemscope=”itemscope” itemtype=”https://schema.org/WebPage”><amp-state id=”td_amp_menu_state”><script type=”application/json”>{
It is showing 404 Page means. Check the image you have uploaded… and have you tried that method
aditya58singh.
Thank you for your answer. @aditya58singh
I have not encountered a problem with the different amp plugin.
I don’t understand where this picture url is coming from.
from this description “apple-touch-icon-precomposed” as far as I understand this is a problem associated with the AMP plug-in or theme.
Hey Catalin,
Please forward a client site with Version 9.6.1 and AMP plug-in for control!
