Confusions with fonts
I have set up Helvetica Arial 13 but it is not responding in Articles. I tried with Arial 14 but the problem is not solved. I’ve always cleaned cache, so please don’t say that’s the problem. I just want to increase the font size IN THE ARTICLES, nothing special.
p.s. in the meantime I saw the menu fonts shrink, without having been touched. There is something wrong. Please help.
The fonts form the posts can be changed by using tagDiv Composer, edit the single post template, select the single post content and check the css tab -> https://i.imgur.com/8KOyNUJ.png -> https://i.imgur.com/wQ6c20O.jpg
Thank you but seams I didn’t make myself clear.
I don’t want to change every single paragraph (this I am already doing, unfortunately), but I would like to set ALL ARTICLES WITH ONE FONT. It doesn’t seem too much, since the function is set up but it doesn’t work.
Unfortunately, there isn’t an option to set the font in one place and this to apply for entailer website. Indeed, you can set it in a few places and will apply for the most of website elements, for this you need to set it in the theme panel (at least in general -> https://i.imgur.com/e5c2CGY.png) and with tagDiv Composer on manager style -> https://i.imgur.com/R0COgH2.png (this will apply the style on the current template and on the cloud header and footer). Now the only problem remains on the blocks elements, on those the style need to be set manually. What you can do is to set the style on one block then just copy the style for the remain blocks.
I hope that this time I understand correctly the question.
Normally, a site has two parts with text: pages and blogs. They are two separate departments. The pages, after adjusting the fonts a while ago, is ok.
While blog fonts does not. Also, the blog do not open articles with Div Composer tags as you suggest.
Why this Theme doesn’t adjust fonts on Blog?
I need to have regular font on blog articles.
Please see attachment
- font how should be, but is ok only on pages
as u see, is possible to open divtag only on pages
https://www.cuori-ribelli.it/wp-content/uploads/2022/03/Schermata-2022-03-04-alle-19.11.38.png
but not on blog.
thx for help
thx
Normally, if you set a page as post page https://i.imgur.com/hSDwCsq.png then this should not have the tagDiv Composer option, the blog should display the latest posts and those should be edited using the theme panel options https://i.imgur.com/c4N2w3A.png (you need to have tagDiv Standard pack enabled for this). Then adjust the fonts using the theme panel settings for modules and blocks -> https://i.imgur.com/nLwFLG9.png
I hope this will help!
This is Article Title button font change!
But what about text?
the problem is right there. It does not exist, I have already searched.
Instead, if the blog template page exists inside theme instead, let me know where it is, so I won’t have to search for hours.
The font is serialized on verdana 11.
Thx in advance
Hi Bozzka,
I think that here was a confusion, when you said blog you mean post/article and not actually the blog option from the WordPress.
So, back to the problem, you want to adjust the fonts (family, size…) on posts/articles. To do this you must first identify if you are using a standard template or a cloud template. The standard templates are coming from tagDiv Standard Pack plugin -> https://i.imgur.com/yS3DSEq.png -> https://i.imgur.com/7WoXXE7.pngand can be adjusted using the options from the theme panel -> https://i.imgur.com/I1rymBA.png -> https://i.imgur.com/cWUEIbA.png
Now if is a cloud template, then it is a single post template and this can be edited using tagDiv Composer (I mentioned something above). -> https://i.imgur.com/GGu2gr5.png select the elements and set the style that you like -> https://i.imgur.com/3pAP4Kn.jpg and the style will be apply on all posts that has the cloud template assigned.
Ok.
I need to open the ticket.
It’s impossible to get the correct answers from you.
Sorry.
