Connect 2 blocks to continue post order
Hi. I want to connect two blocks of to avoid repeated pots. For example a first block with last 4 post. And in other part of my page, a new block with rest of posts (except the last 4)
An example:
1 row: block with 4 last post
2 row: other bloks (ad box, image,…)
3 row: block with 5,6,7,… posts
Thanks in avance.
Rgds.
Yes, you can achieve this from flex blocks settings: https://forum.tagdiv.com/flex-block-settings-guide/
For example, you have 20 posts, for the 1 row you will add a flex block with “Limit post number: 4” and for the 3rd row you can add a flex block with “Offset posts: 4”.
Perfect, it’s just what I needed.
Thanks!!
