Connecting/authorizing instagram does not work
tagDiv Instagram API V2
Instagram Connection Error
Failed to connect account.
Error type: access_token_verification
Error message: error_type: OAuthException error_code: 2 message: An unexpected error has occurred. Please retry your request later.
I tried to connect before, it works, however today…it does not work.
Hello !
Please try to clear your cache and re-try.
Let us know the result !
It worked. I guess Instagram was having a hick-up or just a bad day. It happens.
Im having that same issue, I just realised the Instagram feed has been down. I went to check the settings and saw that the account is no longer connected and trying to connect gives a similar OAuthException error.
I cleared the cache which got me a little further but I still hit the same error
Probably should add that the Instagram images which I was trying to troubleshoot arent displaying but there are broken links for the pictures and you can still click through on them. But still, the other error is true too.
Hello !
We need to take a look and see what can be done there to see if a fix can be done in order to fit your needs.
– admin url and credentials
Our team will take a look !
same issue at my site
Hello !
I Have the same problem at my website.
error_type “OAuthException”
code 400
error_message “Invalid scope field(s): basic”
