Every Content on my Website is on my Host(SiteGround), but when i visit my website it shows ‘Connection not secure’ (Yellow Icon near the Address Bar).
Hosting Support said: Mixed Content: The page at ‘https://www.XXXX.com/’ was loaded over HTTPS, but requested an insecure image ‘http://www.XXXX.com/wp-content/uploads/2020/06/pattern.png’. This content should also be served over HTTPS.
The image in question is this – https://i.imgur.com/z975RUm.png (Tech Demo Theme)
How do i solve this issue?
Please check the configuration for ssl, this will help you to fix this problem, also you can use a plugin like -> Really Simple SSL -> https://wordpress.org/plugins/really-simple-ssl/
The SSL was activated for free by Host Support, they say everything is fine on their end.
Please just give it a try, and test the plugin suggested, in some cases the one from hose is not enough or is not working properly with the theme.
If the problem persists, please provide some more screenshot and details and a link to your website.
