Content / Post Article is out of width on mobile display. We are not using mobile theme.
Please see screenshot , and article example (You have to view the article on mobile to see the problem. Tested on iPhone)
Image Example – https://ibb.co/z504Z7q
Article Example – https://bit.ly/3E5N4BS
Duck
First please do a full backup and please update the theme to Newsmag v5.2.2 after that in case the problem is still persisting, then please check the plugin conflict, please test it only with tagdiv plugins enabled, in case the problem is resolved, then enabled the plugins one by one until you found the one that is causing the problem.
